K-member lightening/ Where are the stress points?
Old Dec 8, 2002 | 05:17 PM
BBB's Avatar
BBB
I am sure someone else has done this already, and has done it better and more informed than myself. I would like to lighten a stock K-member. I know there are tubular K's but they tend to lighten the wallet .
I plan on welding all the seams completly for added strength then drilling (swiss cheesing) the K-member. The thing I don't want to do is ruin the structural integrity of the crossmember.
Does anyone know where the K-member is the most stressed? Where shouldn't I attempt to take out material? Where can I drill to my heart's content?
Anyone with experience here?
BBB
Old Dec 8, 2002 | 05:39 PM
zturbo's Avatar
http://www.smithperformance.com/cata....html#Firebird Front Sub-Assembly
You can see here they just cut out the center and put a bar across.
Steven
Old Dec 9, 2002 | 07:33 AM
OldSStroker's Avatar
Re: K-member lightening/ Where are the stress points?
BBB
Do you really want to do this?
Drilling 25 2 inch diameter holes, or 100 1 inch diameter holes in .140 thick metal will lighten it about 3 lbs., about the weitht of a couple quarts of oil. However you'll compromise the chassis strength substantially.
Much of the torsional rigidity of the chassis comes from this front crossmember. Weakening it is really the wrong way to go, IMO.
If you really want to make a change in front/rear weight distribution, relocate the battery into the trunk....or you could just run lighter weight oil (just kidding, of course).
Old Dec 9, 2002 | 12:11 PM
mongse_1's Avatar
I'd just get the BMR k-member. Wait until someone has a GP on BMR stuff and get it for a little cheaper. It'd be a lot easier and safer than hacking on your own k.
Thanks for that link Steven. Found some stuff I might use in the future.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
