Torque Arm Conversion! HALP!
Im doing the 3.4 to Carb swap in my 95, and I know I need the BMR transmission convertor bracket, but then I noticed I need a new torque arm (ala third gen ) So I browsed to it and it's 550.00 friggen dollars, because it's designed for drag racing!! I do not want/ want to spend 550$ on something that is basically overkill. I do not drag race or any kind of race!! Anybody know where I can get just a NORMAL torque arm conversion for my 95?? Again, Jesus! 550$
-Rabid
-Rabid
Re: Torque Arm Conversion! HALP!
-Rabid
-Rabid
If so, and you don't plan to go racing, why are you pricing out BMR's $550 "Xtreme Duty" unit intended for 9-second cars? They offer the "Trak Pak" for $330 which would be more than adequate for your purposes. Spohn also makes a TA for around $350 that will handle just about anything you could throw at it, under 1,000HP. And the design is simple enough that you could probably fab one up for about 1/2 of that.
RUENUF
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
