Allison 5-Speed auto.
Old Dec 14, 2002 | 10:10 AM
EricTheBald's Avatar
I'm getting interested in this tranny but I am amazed at how little info there is on it.
Does anyone know the following?
[list=1][*]What are it's physical dimensions?[*]What ratios are available for it, for each of it's five gears?[*]Can it be done as a "no-electronics", full manual tranny like the 4L80E?[*]If not, are the factory electronics easilly mated to LT1/LS1 engine electronics?[/list=1]
Any technical info on these wanted.
I do know they take about 17 quarts of oil and they are supposed to be physically huge.
A guy I know on another board described it as: "This thing is at least twice the size of a TH400 and it is larger than my toyota auto and transfer-case combined.
Old Dec 14, 2002 | 10:14 AM
rskrause's Avatar
Moderator
They are huge. Go to a Chevy/GMC dealer and find a truck to look under. It looks about the same size as a 350 block! Also, if you are thinking of using one there would be a LOT of issues besides size. You mention ratios, then there's cost, how to contol it, etc.
Interesting thoght though. I'll bet they are mucho dinero.
Here are some specs: http://www.allisontransmission.com/p...tionsheets.jsp
Note the following:
Length (SAE No. 3 flywheel housing to park brake mounting provision) 27.35 in (694.7 mm)
Length (SAE No. 2 flywheel housing to park brake mounting provision) 27.73 in (704.4 mm)
Depth (below transmission centerline) 11.22 in (284.9 mm) - standard oil pan
Depth (below transmission centerline) 10.71 in (272.0 mm) - shallow oil pan
Weight (dry) 330 lbs (150 kg)
Add 13 quarts of fluid and it's nearly as heavy as an LS1 motor!
Rich Krause
Old Dec 14, 2002 | 11:26 AM
That is heavy.
I guess on the bright side it'll put that mass dead center in the car.
Thanks for the link.
Old Dec 14, 2002 | 11:35 AM
I think I asked this question about the Allison 1000 5-speed about 3 months ago, and got the same response. If you would like some actual dimensions, a friend of mine has one behind a Vortec 8.1L engine.
Old Dec 15, 2002 | 04:42 PM
Sure, that'd be cool.
He doesn't need to take a mike to it, just a basic idea would be good.
Old Dec 15, 2002 | 05:55 PM
OneFlyn95z28's Avatar
this is definately not a car transmission
Old Dec 15, 2002 | 06:21 PM
rskrause's Avatar
Moderator
Um, I posted the dimensions above. They are available in more detail if you follow the link.
Rich Krause
Old Dec 15, 2002 | 10:06 PM
Yeah, you're right.
I don't know where my mind was, sorry.
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
LazyLemming
Aug 29, 2015 07:36 PM
67chevy
Parts Wanted
Jul 20, 2015 02:27 PM
