Pistons: Do they need to be matched perfectly gram for gram?
Old Dec 4, 2002 | 11:31 PM
AutoRoc's Avatar
Lightbulb Pistons: Do they need to be matched perfectly gram for gram?
I have a new set of SRP Pistons that are being coated right now and the weight of each pistons is different as much as 1.2 grams. Should I balance them 100% perfectly? IS there any benefit? Is it a normal procedure that evereyone should be doing? any info would be nice! Thanks fellas
Old Dec 5, 2002 | 02:29 AM
89ProchargedROC's Avatar
if you wanna be **** go right ahead. You'll be fine
Old Dec 5, 2002 | 04:44 AM
rskrause's Avatar
Moderator
Re: Pistons: Do they need to be matched perfectly gram for gram?
1.2 grams is much better than OEM tolerances. Some engine builders will get them a little closer, but 1.2 grams is plenty close. What you can do is put each piston pair that's closest in weight on the same crank pin, but it probably makes no difference either.
Rich Krause
Old Dec 5, 2002 | 07:11 PM
AutoRoc's Avatar
Thumbs up tregt
Thanks fellas..
Old Dec 6, 2002 | 01:33 AM
Ai's Avatar
Ai
LOL, that reminds me of my buddy Jack . He'll spend all day long trying to get a crank within a tenth.
Old Dec 6, 2002 | 12:23 PM
ws6transam's Avatar
Well, I guess you can go ahead and call me ****, then. I matched each of my pistons to within 100 milligrams, and then did the same with each rod: big end to big end.
The engine shop in texas (Dallas Export Sales) then weight matched the whole reciprocating assembly to half a gram.
BTW, Denny I finished the ceramic coating on the piston tops. Now I have to do the skirts in DFL. The tops look pretty nice. Did you receive the link to the pictures?
--Dan
Old Dec 6, 2002 | 01:56 PM
TunedPort 335's Avatar
Sounds like your all set to me.
When I had my bottom end balanced, they did everything with 1.0 gram.
So your 1.2 should be fine
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Aug 7, 2015 01:26 PM
Aug 5, 2015 08:35 AM
Boss002
Jul 24, 2015 10:47 AM
Jul 10, 2015 02:23 PM
