front k member
Old Nov 22, 2002 | 12:59 PM
jimmbo's Avatar
front k member
if you install the tubular front k member from say.......pa
and purchase tubular a arms
do you need to go to coil overs and get the k member with motor mounts and spring perches?
or can you keep the stock springs and shocks with the tub a arms and the k member?
Old Nov 22, 2002 | 01:01 PM
jimmbo's Avatar
sorry this is for a 90 camaro witha bbc.
Old Nov 22, 2002 | 01:29 PM
MRZ28HO's Avatar
Exclamation
Although I am not using a BBC, it is similar to an SBC. If you opt for the spring perches, you'll be able to use the OEM style springs and struts. With either, you'll need the motor mounts. Otherwise you won't be able to hold the engine in. If you want to convert over to coil over, you should not order the spring perches. I have a PA K-Member with motor mounts and spring perches on my thirdgen, because I am using OEM style springs and struts.
Old Nov 22, 2002 | 02:38 PM
jimmbo's Avatar
thanks for the reply
it cleared up much confusion for me
now i just need to decide how far i want to go.
jimbo
Old Nov 24, 2002 | 02:03 AM
zturbo's Avatar
Like in the line of Cannonball Run.....
If your gonna be a bear be a GRIZZLY
Steven
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
CARiD
May 6, 2015 07:49 AM
R@mpage
Apr 20, 2015 10:02 AM
8T8IROC
Mar 26, 2015 09:02 PM
