Block filler ?s
Old Dec 13, 2002 | 05:57 PM
mongse_1's Avatar
Block filler ?s
I know it's not for street cars, but I'm still curious about it.
Any recommendations when doing it?
Is there a certain material that is recommended?
Would this be feasible on an LT1 w/ the reversed cooling flow?
How far do you normally fill up to?
What's the advantages?
Old Dec 13, 2002 | 06:04 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
who told you it wasnt' for street engines? my 401 had filler.
materiel? yes.. block filler
on my 401 i tilted the block while it was curing, so I only did the thrust side.
Old Dec 13, 2002 | 08:01 PM
Stephen 87 IROC's Avatar
There's pros and cons to using block filler. You don't want it in a street engine. Rarly is it used on an engine that runs gasoline. Most of the time it's for alcohol engines since they run cold enough that coolent in the block isn't a concern.
A block is usually filled to the bottom of the water pump holes. Properly done, the block is tilted so that the cylinders are verticle. Then the block filler surrounds the entire lower part of the cylinders.
I wouldn't worry about block filler unless you're building 700+hp. It just strengthens the lower parts of the cylinder walls.
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
