anyone used hardened axles in a 10 bolt?
Old Dec 2, 2002 | 08:41 PM
redz_02's Avatar
Question anyone used hardened axles in a 10 bolt?
Has anyone used hardened axles in a stock 10 bolt. I will be getting my 4.10's and rear girdle put in as soon as i get my wheels and tires, then i thought, why don't i try and replace the axles with some hardened ones while i was at it. I don't plan on any more big mods other than heads and cam in the future. I used to always put moser axles in my friends 5.0's and i was wondering if anyone has done it to an ls1.
Old Dec 2, 2002 | 11:24 PM
Stephen 87 IROC's Avatar
Before I switched to a 9" I was running aftermarket axles in a 10 bolt. "IF" you manage to break a factory axle before breaking teeth off that tiny ring and pinion, then consider going to an aftermarket axle. Chances are you'll shear teeth off first.
I went to a 9" because of a very high stall converter and a transbrake. I didn't think the 7.5" ring and pinion would take more than one hit off the transbrake.
HectorM52
Jul 30, 2017 11:46 AM
HarleyZ28
Oct 5, 2015 06:23 AM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
Catmaigne
Dec 25, 2014 12:16 PM
