Solid roller guys, what springs and pressure you running?
Old Dec 8, 2002 | 09:55 PM
LTOne4Fun's Avatar
Loking to see what pressure to run with a mild solid rolelr cam with about 600 lift, less than 230 duration
Old Dec 8, 2002 | 11:03 PM
SStrokerAce's Avatar
As far as I know you can't get .600 lift and less than 230 duration from a solid roller. I'm sure there is alobe out there but I haven't seen it.
Basically alot of spring is needed. I would say a Comp 987 or 977 or maybe even a 929.
Bret
Old Dec 9, 2002 | 10:07 AM
EODUSMCR's Avatar
I think he is refering to the new CC xtreme energy solid roller cams that are out. I am thinking about going with this one: .564/.570 (.601/.608 w/1.6 rockers)@.050 236-242 LSA 112
I know the the LSA isn't a aggresive like a 108 or 110 but, I still want this to be more of a mild setup.
Old Dec 9, 2002 | 11:10 AM
bowtiepwr's Avatar
>With the solid roller cam ... how often do you have to reset your lash on the rockers ?
Old Dec 9, 2002 | 12:49 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Run comp 943, pacalloy.. IMO, only solid roller spring to use.
I would run around 230 on the seat (starting). they will soften with use. keep it over 200. what did the cam manu recommend?
Onces the parts break in, you will ahve to adjust rockers every 2 oil changes or so.
Old Dec 9, 2002 | 02:31 PM
LTOne4Fun's Avatar
Jordan, 230 on the seat really? I thought that was normal for a 650 lift roller, but with a much milder cam wouldnt that be overkill? Is the drag associated with too much spring pressure not a concern, I guess yo wont collapse lifters like a hydro
Old Dec 9, 2002 | 03:18 PM
bowtiepwr's Avatar
>I hope who ever has one of these isn't using a Vortech After cooler .
I think I will stick with the hyd.roller .
Old Dec 9, 2002 | 03:37 PM
230 on the seat new.. IE, they will be in the 21X range after you put a couple miles on them.
IMO, its better to be a little on the heavy on a street car.. because they WILL lose pressure
Old Dec 9, 2002 | 07:18 PM
LTOne4Fun's Avatar
Ok so you recommend the same sprigns you ran with your moster cam right jordan Just want to be absolutely sure when I order parts
Old Dec 10, 2002 | 02:24 AM
jimlab's Avatar
I second that.
Old Dec 10, 2002 | 06:07 AM
chevyguy3's Avatar
i use the 943s on my street/strip car too
Old Dec 10, 2002 | 09:17 AM
Jason Short's Avatar
943 pacalloys on mine as well
Jason
Old Dec 10, 2002 | 09:23 AM
PatrickCarter's Avatar
943s on mine as well...
P
Old Dec 10, 2002 | 10:48 AM
89ProchargedROC's Avatar
PSI springs are a better option and hold spring pressure longer according to my engine builder and head porter....they are expensive though
Old Jul 13, 2003 | 05:10 PM
SILVERZZ28's Avatar
I am running a solid roller 247/252 .640lift on a 112Lsa. I am running the 943s with cranes 11552 lifters and I was told to stay around 180seat pressure due to possible breaking the rocker studs. I m running comps 7/16 studs on a LT1 head. I also thought that I should be around 220 but I did not want to risk the the car breaking. This is a daily driver. Can someone shed the light on if I would ok to go up on the spring pressures?
