Hot Rockers
Old Nov 27, 2002 | 09:45 PM
TransAmGT's Avatar
Hot Rockers
Man these things are awesome...I don't know if you no what these are, if you don't take a look here cause it takes way too long to explain! : www.hotrocker.com
What do you guys think about these??? only $900
If I had the money I'd get them!
Old Nov 27, 2002 | 10:33 PM
OldSStroker's Avatar
Not to be a wet blanket, but...
Where did they get a 228* cam with .394 lift (1.5 rockers). Even OEM's don't get that mild on the flanks.
83 (almost 35%) more hp @ 5250 with just rocker arm ratio?
120 (almost 52%) more torque at 4000 with just rocker ratio?
85% of max torque from 1750 to past redline.
90% of max torque from about 2600 to 5100.
WOW! OEM's need variable valve timing of up to 50 crank degrees to achieve those numbers.
325 max hp? 361 max torque? GM's aftermarket Vortec head HO crate engine makes 330 hp @ 5000 and 380 lb-ft @ 3800 with less cam. (212/222) and costs about $2250 for the complete longblock with all new parts. Tell me why I want to spend $900 just for rocker arms?
Yeah, I guess I am a wet blanket.
Old Nov 27, 2002 | 11:08 PM
NOMAD's Avatar
Cool
Those things are ooolllddd... You could probably o a search and find a hundred threads on it. I dont' think the technology is all that great. I mean really, Vtec isn't all that special
-Shannon
Old Nov 28, 2002 | 02:54 AM
Mr. Horsepower's Avatar
V-Tec is a cam-changing design and it's very compromised toward it's long duration camshaft change. Without a much more complex actuation, and a 'system' built in accordance to power output at varying levels, there are always going to be compromises in these types of designs.
The problem with this system in particular (as I see it) is one of durability. The rocker arm is weak in it's most critical area, directly below the arm, and the little 'actuating-notches' don't help the situation much either. With this system you get one thing... variable lift which has a few advantages to it but not as much as they'd like you to believe. What you don't get is a system that works in concert... ie, variable lift, variable timing and variable runner length. From there, we work towards a throttle-less system like the BMW Valvetronic. Big advantages there but it's also very expensive to design and manufacture. Even at it's best, you might see a 15% increase in engine performance with much lower emissions and markedly better fuel economy.
I'm not going to say the system doesn't work, I just believe that you would not want something like this in a high performance application. The rocker arm looks like a real weak link and I think the harmonics of the system would really limit top end power. Those are my thoughts... no actual data, just a few years actually building custom shaft-mount rocker systems for many of our customers. Take from it what you will.
Take care,
Chuck Riddeck
Progressive Race Engine Development
Old Nov 28, 2002 | 09:59 AM
NOMAD's Avatar
Cool
Chuck has a good point with harmonics also... Remember an lt-1 has a knock sensor in it, so i'm sure it would drive those cars crazy...lol
-Shannon
Devinfoote87
Jul 30, 2015 09:54 AM
jbc3
Jul 28, 2015 12:24 PM
Xiantyl
Jul 21, 2015 05:42 AM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
