Duramax Diesel 32 valve heads on LS1?
Since the Duramax diesel uses aluminum 32 valve heads that are pushrod actuated. It is possible to bolt these heads onto an LS1 block? If these heads are a direct bolt-on than this would be a crazy combination!
http://www.truckworld.com/Truck-Test...silverado.html
The Duramax is an Isuzu engine. It has nothing in common with a GM block.
Diesel heads have no combustion chambers in the heads. The combustion chamber is in the top of the piston. If there was some way to bolt the heads on, the valve train geometry wouldn't work.
You might as well be asking if Ford 4.6L heads will bolt on.
First, by design diesel heads have to be different then gas heads (spark plug, vs injector…).
If it wasn’t for that the most cost effective way to go is to find a head that has the same bore spacing, though it would be more difficult on a V 8 engine. A good example of this is that the Volvo DOHC heads can be made to fit a ford 2.3, only needing modifications for one bolt hole per cylinder and working out appropriate manifolds. Assorted SBC and V8 Poncho parts can be made to work on Iron duke 2.5L 4’s, and aftermarket blocs are available that make most V8 heads a bolt on.
Originally posted by WS6 TA
32 is better then 16?
Personally, I'd be happy to get an LS1 style head on a traditional SBC, the best of both worlds...
The GM Splayed valve head, commonly known among racers as the 517 is a symmetrical port head just like the LS1/LS6. Better yet, it uses a valve cant.
The same can be said of the 'old' Dart Buick (Chevy small-block) heads. Brodix also has a symmetrical port head, the BD 2000. So there are choices if you have the money. On top of that, I'd say that the SB2.2 is a better head than the LS, even without the symmetric ports.
-Mindgame
http://forums.stangnet.com/showthrea...hreadid=261999
Originally posted by Mindgame
You can.
You can.
Originally posted by rskrause
Maybe you could fit a Ferrari F1 head with electronic valve actuation on a big block and throw it in your 4th gen.
Maybe pigs will fly.
Rich Krause
Rich Krause
'Warthogs' fly.
Strange thread, this.
