LT1 block/SBC Crank Mismatch?
Old Jan 2, 2003 | 05:44 PM
Warlock 95Z's Avatar
I have a 400 crank in my MTI built 409 c.i. Lt1 stroker. The rear main seal leaks apparently due to the adapter which is necessitated by the combination. The machine shop who has the motor now claims that a "re-machining" of the area and putting on a new adapter will solve the problem. This scenario is over my head, so I don't have any way of gauging whether or not they are honest. Hopefully you guys can offer your $.02
Old Jan 2, 2003 | 05:58 PM
Mindgame's Avatar
Here's what I know about the situation... If the seal adapter is not installed correctly, it may move in relation to the crank and that'll cause leaks. Most machine shops use an arbor that positions the seal adapter, they then drill and ream the adapter and block at the same time. Then they install alignment dowels in the block and install the adapter. If installed properly, it won't leak.
Now your problem could be a misaligned adapter or it could simply be a seal. I'd want to see the seal before having them do any work. Hope this helps a little.
-Mindgame
Old Jan 2, 2003 | 10:48 PM
zturbo's Avatar
Did you call Jayson by chance to see what he had to say about the whole thing?
Steven
Noer
Feb 28, 2015 11:29 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
