Steering column lock/key assembly removal
Old Dec 31, 2002 | 02:19 AM
Don Lindsey's Avatar
No, I'm not trying to steal a 4th gen . . .
I'm getting my '97 camaro set to go again for race-only duty and I need to get the steering column lock and key assembly out and disabled.
Anyone with some auto-theft experience care to help me??
Thanks!!
Don
Old Dec 31, 2002 | 03:12 AM
Prince's Avatar
Are you trying to use a toggle switch to start the motor (totally bypass the key altogether)? Although I don't have much knowledge of how exactly people set-up for "race only", maybe I can still point you in the right direction.
The easiest way I can see to accomplish this is to leave the ign. cyl. alone. If you drop the column, you'll see a white box. This is the "brains" of the ignition as far as the positions of the key. As you turn the key, there is linkage that slides contacts. It's abit hard to explain (especaily at 4am ), but you'll see what I mean. You can then take the wires off of that box and use switches and relays to make it work w/ out using a key.
Again, I have no experience with setting somthing like this up (have had no need to), but if I were to this is prob. what I'd do. If any one else has a different/proven way, hopefully they can chime in.
Dave
Old Dec 31, 2002 | 03:34 AM
Ok, thanks, but I should have added more info . . .
Every solitary peice of wire has been removed from the car. The dash has been stripped, cut up for weight savings and its shell reinstalled. I'm temporarily using the stock column (which has also been stripped of all parts/wire) and I want to get the lock/tumbler out for saftey reasons and so I don't have to keep track of a key just to drive the car.
Thanks!!
Old Dec 31, 2002 | 07:09 AM
Z28tt's Avatar
Shouldn't this be better off posted in the 3rd gen or 4th gen forum? I'm not seeing how this is advanced tech...
A.
Old Dec 31, 2002 | 09:08 AM
Well . . . there wasn't an "Auto Theft" forum, so I figured this was the next best option since it isn't mainstream tech like "why don't my power windows work" or "which panhard bar is the best".
Old Dec 31, 2002 | 09:32 AM
drop top steve's Avatar
You need to remove airbag/streeing wheel, lockplate, turnsignal switch. Now you can remove a single screw that holds the key switch. I would also take the pin that engages the lock plate out.
You need a hub puller fot the streeing wheel and a lockplate depresser to get the snapring out that holds the lock plate.
Old Dec 31, 2002 | 12:35 PM
LT1 Tech, or Drag Racing.... or maybe just try a Chiltons or a Helm.
But not Advanced Tech.
Victor Lamb
Aug 26, 2017 02:52 PM
nikko
Apr 28, 2015 10:05 AM
pologreen97z
Dec 2, 2014 10:42 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
