Fuel Regulator and Injectors
Old Feb 5, 2006 | 12:09 PM
Lance95Z28's Avatar
I have just purchased a zex kit. Should i put bigger injectors in and if so how big 36or 42? Also should i buy a regulator if so which one is the best and also abotu how much pressure should i be running??
Old Feb 5, 2006 | 09:27 PM
n2oCamaro's Avatar
Re: Fuel Regulator and Injectors
Need more info on your set-up. Is this a stock/bolt-on car or more? The stock injectors are supposed to be good to almost 400rwhp. A dyno and scan of the injector's duty cycle will tell you for sure. 90% or higher duty cycle will warrent bigger injectors. You probably won't need a different regulator. Most systems are set-up for stock fuel pressure. The Zex being a dry kit is set up to regulate fuel pressure anyway.
Old Feb 7, 2006 | 11:56 PM
LT-7's Avatar
I had a wacko tune in mine and on the datalogger it showed 98% DC. Turned out it was waaaaay too rich and once I corrected it it dropped to the 70's - 80's.
dfarr67
Apr 10, 2015 07:44 PM
LT14LIFE
Feb 9, 2015 09:35 PM
birdblack
Dec 30, 2014 06:59 PM
siguy
Nov 27, 2014 10:07 AM
IDOXLR8
Aug 6, 2002 12:30 PM
