NX Universal Bottle ?'s
Old Feb 18, 2006 | 07:02 PM
johnny3986's Avatar
I bought a universal kit off a buddy and have been piecing together the entire kit before install that way I have everything set.
WOrd on the street (or track rather) is that I have to have the blow-down tube kit since I am mounting it inside the car.
The top off the bottle has four outlets on the valve.
- main nozzle
- one smaller one blocked by an allen wrench plug (like a diff plug) on each side (left and right)
- a plug covered by a rubber disk, with a small hole in it on the back (but the cover isn't on it in the picture)
[IMG]C:\Documents and Settings\Administrator\Desktop[/IMG]
Where did I mount this blow down kit?
Where did you guys mount your bottle at?
I am planning to mount it on the hump between the rear seats unless I put it behind the driver's seat since stereo is in the back and I refuse to take the spare out.
EDIT: How the heck do I post pics on this thing??
Old Feb 19, 2006 | 08:15 PM
johnny3986's Avatar
Re: NX Universal Bottle ?'s
Ttt
Old Feb 20, 2006 | 10:28 AM
Nitro Dave's Avatar
You will remove this fitting. Then the NHRA fitting will take its place. The NHRA fitting is threaded on both ends. The outside thread is a -8. Now your blow down tube will screw directly on to this fitting.
Check this link out for a great bracket to mount the bottle between the seats.
http://www.nitrousoutlet.com/outlet/...section_id=141
Old Feb 20, 2006 | 10:36 AM
johnny3986's Avatar
Thanks! The guy who I bought it had the whole thing hard wired to a switch that was laying on his floor that he kicked....
On top of that, the bottle has no gauge, and no blow down tube.
I was already looking at that bracket, but how does it mount to the car? Does it come with hardware? If not, what do you suggest?
Old Feb 20, 2006 | 05:59 PM
Nitro Dave's Avatar
Yes the bracket comes with the mounting hard ware. You will drill 4 holes and the unit bolts in.
Dave
Quickss96
Jan 29, 2016 05:56 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
Pwilson59
Sep 3, 2015 08:47 PM
weedog
Aug 15, 2015 08:23 PM
Jul 17, 2015 02:47 PM
