N20 questions
Old Feb 23, 2006 | 06:57 AM
96badbird's Avatar
N20 questions
im picking up a used nos wet kit this weekend. anything imparticular i should look for to make sure everything is functioning right and can someone email me a basic install guide or maybe a few tips
larrypat@hotmail.com
thanks
larry
Old Feb 23, 2006 | 09:48 AM
BlownF1's Avatar
Re: N20 questions
Check their website...most manufacturers have install guides on there. Basically, unless it's still installed, all you can really do is verify the appearance of everything. Plan to rebuild the solenoids (should be kits available) and closely inspect all the wiring/hoses. If the kit appears to be complete and in good shape, it should be fine...there's really not a lot to them. Most of the replacement/rebuild parts are pretty cheap. You could activate the solenoids by putting them directly across 12v, but that will do nothing for verifying they don't leak...but again, you should probably plan to rebuild them anyways.
Old Feb 23, 2006 | 03:38 PM
Re: N20 questions
This site is pretty decent for basic info, and is LT1-sepcific:
http://www.ny-trex.com/html/nitrous_101.html
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
T/A lt1
Oct 10, 2002 03:14 PM
PhantomTA
Sep 7, 2002 08:44 AM
T/A lt1
Sep 5, 2002 06:53 PM
