anyone have the nitrous works plate kit for lt1
I had my jets and the card that came with the kit in the console of my car and someone stole it. So I was wondering if anyone knows the jet numbers for the horse power levels. I would appreciate any info. I don't get to the track much and have a chance good friday. I called jegs for the jet pack and they said it woild take at least 10 buisness days to get it so there is no way for it to get here, but they said I could use nos jets if I knew the numberes needed.
Re: anyone have the nitrous works plate kit for lt1
I have ran this kit on my s10 which had a 95 lt1 in it with a stock fuel pump and this is the same situation on my 93 camaro. I sprayed the s10 175 never sprayed the 93 more than a 100. I have only sprayed it once it went a 7.90 in the 1/8 th.
my fuel pressure is around 43-45 psi on a stock fuel pump with a racetronix wiring harness. i need to install the new pump soon.
Originally Posted by 1970z28
nfa: what fuel pressure are you running with this system.
oldschool
Feb 9, 2016 09:21 PM
