Help a n2o noob please =)
Okay, so my goal is low 12's. I have everything in sig except ive got a new granatelli 255lph fuel pump and 3.23 gears. I plan on buying new opti/plugs/wires, dr's, ram hd clutch, phb and some lca's. I know pretty much nothing about spraying these cars. I need to know the most cheap/safe way to get the numbers i want. The only time i will be spraying is at the track and for setup races. Any good online kits i should be looking at? Anything else i need to do to prepare my car for this? Motor/trans and rear have about 75k .. if that means anything. Thanks for any help.
Re: Help a n2o noob please =)
THe key to a safe nitrous system is quality parts complete with the needed safety accessories.
You will need to change your spark plugs to NGK tR6s. You may need to pull some timming since you have a custom tune.
I suggest checking out our February specials. The single nozzle wet system would work great for you.
Dave
Dave
