Wiring
Old Jan 25, 2006 | 05:44 PM
RedTtop6spd's Avatar
Wiring
Out of curiosity, what's everybody's favorite methods of getting wires from the engine bay to the passenger cabin for things such as arming switches. Also with the bottle somewhere in the passenger cabin or in the trunk, getting the supplly line into the passenger cabin. I'm just curious about what different methods people have used. Personally, I drill a hole in the side by my feet under the interior panel and then route things through the fender over the wheel well.
Old Jan 25, 2006 | 05:55 PM
"White Knight"'s Avatar
Re: Wiring
Your doing it the hard way. Drop the passanger kick panel under the dash. Open your hood, go to the far left corner and there are two bolts that hold the ECM in, take those out and pull the ECM up a and out a little (leave pluged in) and you will see the rubber gromett where you should run wires and nitrous line through.
Old Jan 25, 2006 | 06:50 PM
Re: Wiring
That's nice to know. My 85 Camaro already had a hole through the side by my feet.
Old Jan 26, 2006 | 10:37 AM
Re: Wiring
ah it's an 85
Old Jan 26, 2006 | 11:34 AM
Re: Wiring
Yeah, that would be the dead 85. I have a 99 SS now...with no holes in it.
Old Jan 30, 2006 | 02:42 PM
joeZ96's Avatar
Re: Wiring
Were you able to actually run the nitrous line through the sealed grommet? I was able to run a couple of small wires through there, but I don't think I could of run a nitrous line without tearing it.
Old Jan 30, 2006 | 04:48 PM
84 monte SS's Avatar
Re: Wiring
take the grommet out.
Old Jan 30, 2006 | 05:02 PM
joeZ96's Avatar
Re: Wiring
Then you'll have a puddle of water sitting on the passenger floor if the car gets stuck in a downpour.
Old Jan 30, 2006 | 06:30 PM
Re: Wiring
Yes sir. There is plenty of room. Leave the grommet in so the Nitrous line doesn't rub against the metal and wear the stainless line. It's been done many times, and works out very very well.
Old Jan 30, 2006 | 06:32 PM
Re: Wiring
Actually that hole is tucked way back in there, not much water would ever get up there that's the why they tuck the ECM up there. The main reason is so the line doesn't get worn or cut from rubbing.
Old Feb 1, 2006 | 03:28 PM
BlownF1's Avatar
Re: Wiring
I hope you fuse any power leads you run through there!
Old Feb 3, 2006 | 03:53 PM
Re: Wiring
Definately do and i havent had any water come in or any problems for over a year now....
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
