A new Product..
Old Feb 14, 2006 | 07:26 PM
Nitro Dave's Avatar
A new Product..
I know that there are probley very few if any GTO guys here but I thiought I would share this new desighn here also.
As many of you know here at Nitro Daves we strive to create and build new desighns and products so that you have the best quality and desighned products possible for your application.
For the last few months we have been building two new dry kits for you GTO guys.
The first is our Halo dry system. This system places a spray bar in your stock air box. This desighn will better attomize the mixture of nitrous into your air stream. This system will give a hidden install to keep your compition scratching there head.
You can find this system on this months Nitrous specials.
This is the stock GTO Air Box. With the concelled system.
Once removing the top. You will see our custom one of a kind Halo spray bar.
The jet will go in the Halo fitting where the line screws on. Notice the fitting comes through the filter.
Your solenoid will mount inside the box with two push pins or nuts and bolts.
You can mount the relay right inside the box. Then all you need to do is finish the wiring. Make iit look nice with some wire loom and you are ready to go.
The second desighn we are building is for you guys running the after market cold air kits with cone style filters. This desighn will give you a much cleaner concelled intsall that the current methods. WE will hopefully be releasing pics sometime real soon.
So what do you guys think?
Dave
Old Feb 14, 2006 | 07:37 PM
alteregoss2000's Avatar
Re: A new Product..
Anything like this for ls1 camaro's. Looks good.
Old Feb 15, 2006 | 12:49 AM
94BlackT/A's Avatar
Re: A new Product..
That looks sweet.............
Old Feb 15, 2006 | 02:24 AM
TMoNeE98's Avatar
Re: A new Product..
Looks good Dave
Old Feb 15, 2006 | 01:47 PM
Nitro Dave's Avatar
Re: A new Product..
You bet. Thats where this all started.
JBsC6
24
Nov 2, 2010 02:36 PM
camarobabe02
42
Jul 24, 2004 11:59 PM
tekker
May 13, 2004 03:13 PM
nd4spd200
Jan 25, 2004 05:34 PM
