Nx Wet kit and msd window switch question
Old Jan 5, 2006 | 11:28 AM
always faster's Avatar
Ok im gonna buy a NX wet kit for my 95 lt1.Because i new to this world(n2o) i have a couple of easy question :
-Can my stock lt1 take 100shots without any problem?(engine as a perfect compression,doesnt burn oil at all)
-Is this windows switch will work on my car(i think so):
MSD-8969 digital msd window switch :special 89.95$ at summit racing
-What would be a good setting for the rpm(was thinking about 3000rpm to 5600rpm)
-Do i need something else except the nitrous kit(that come with all the hardawre,wot switch and everything) and the window switch?
Thank you all for your help
Old Jan 5, 2006 | 11:05 PM
Nitro Dave's Avatar
Re: Nx Wet kit and msd window switch question
The NX single nozzle kit is a nice system. The MSD wiondow switch will work juts fine. Your stock motor will take a 100 shot with no problems.You need to look into a bottle heater,pressure gauge,purge ,fuel pressure safety switch and NHRA fitting and blow down tube if you want a complete set up with all the accessories to help the system fuction to its full potential. NX makes a sytsem calles a GENX2 package.This will be a all in one system for all the accessories.
Dave
Old Jan 6, 2006 | 08:07 PM
OBE1 95Z28's Avatar
The MSD window switch uses "pills" to set the rpm trigger points. This is a pain in the a** when you want to change settings as the pills come in a sets of 5 and are expensive. I got a Mallory window switch that has rotary wheels that lets you "dial in" your trigger points.
Old Jan 6, 2006 | 08:09 PM
OBE1 95Z28's Avatar
By the way, it's the Mallory P/N 628 RPM Window Switch
Old Jan 8, 2006 | 03:32 AM
Cmr0z28's Avatar
Don't get the MSD digital switch. A LOT of them turn out to be defective. Mine was.
alphaauto
Jan 23, 2015 07:42 AM
RedLineRev
Jan 23, 2003 03:51 PM
Rich_z28
Aug 29, 2002 10:44 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
