Wiring Mallory 685 with nitrous
Old Jan 28, 2006 | 11:19 AM
nfa's Avatar
nfa
Hi,
I just got a mallory 685 box and have the harness to splice into the coil. I am not 100% clear on how to wire the yellow wire for timing retard and the wire for the window switch operation into my system. My nitrous system uses 1 relay, FPSS and WOT switch.
Any help, or better yet a diagram, would be super useful!!!
michael_w_ma "at" hotmail.com
Old Jan 28, 2006 | 07:16 PM
Cmr0z28's Avatar
Re: Wiring Mallory 685 with nitrous
With my MSD, there is a 12v activation wire to retard timing. When it has power, timing is retarded. This taps into the 12v wire that feeds the nitrous solenoid, so it only retards timing when your N2O activation switch is on.
Old Jan 29, 2006 | 11:07 AM
FMFRacing88's Avatar
I wired the timing retard from my 685 to the WOT switch so when the WOT switch is activated it activates the timing retard. As for the window switch from the 685 I wired that to the ground on the nitrous soleniod.
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
