Ignition box, and window switch?
Old Jan 24, 2006 | 03:37 PM
Grims's Avatar
I have a NOS kit, and recently had a problem with a backfire porting my MAF for me.
i would like to get a window switch and ignition box to make things a little safer.
What is a good budget system?
Old Jan 30, 2006 | 09:02 PM
Hawk's Avatar
Re: Ignition box, and window switch?
I use the MSD window switch and the accell 300+ ignition. However, if your going to shoot over 100 shots, I'd get a digital MSD ignitino because it has built in timing retard.
Brian
Old Feb 3, 2006 | 07:49 PM
OBE1 95Z28's Avatar
I have the Mallory window switch that has setable dials for on and off rpm levels. The MSD window switch required pills which are expense.
Old Feb 3, 2006 | 09:48 PM
Dave 96TA's Avatar
The Mallory Hyfire has all the options you'll need, single box, all digital
Here's one at Jegs
http://www.jegs.com/webapp/wcs/store...tegoryId=18101
Old Feb 3, 2006 | 10:18 PM
Grims's Avatar
I just bought the 685, can it retard timing if the wheels start to spin?
Old Feb 3, 2006 | 11:09 PM
Bow94z's Avatar
Now that we are on the topic of the Mallory 685 box, where is everyone moutning the box at?? Sorry TA Body this may help you out aswell, im curious.
Old Feb 4, 2006 | 01:39 AM
Mikes 1994 z28's Avatar
I mounted my box in the glove box. I havent had any problems with heat at all. It is stealth also. Check out my post on www.z28.com in the nitrous section. You will find pictures of my install.
Old Feb 4, 2006 | 11:34 PM
LT-x7's Avatar
What harness did you use to install it? Does mallory make one for the LT1 or did you just use the MSD harness?
Old Feb 5, 2006 | 12:18 PM
AlwaysCode390's Avatar
I have the 6853M Hyfire 6-AL....it doesnt retard timing does it? Will it just make spark better and have a rev limiter? I think I got the wrong one....I want the one posted above, lol :doh: ---
I was planning on using it for my 96 w/ a 125 shot OR my 67' with a 142 supercharger....will it work with either!? What parts do I need to add to still use it? THANKS---
Old Feb 5, 2006 | 12:46 PM
my94blackz's Avatar
I like the msd digital 6 box. I believe you can also hook a window switch into it. Here is a pic of how i mounted mine.
Pardon the mess that was during some winter cleaning. But if you look closely you can see where I took a ziz wheel and cut the wheel well knocked it back, welded in some metal, and placed the MSD box in its newly made home.
There is the completed engine compartment.
Old May 26, 2006 | 05:02 PM
On the Mallory 6cd box it says " Boost sensitive proportional ignition timing retard available with optional MAP sensor kit " . Do I need the MAP SENSOR KIT running the bottle or is that for turbo/supercharged "boosted" engines? Would I benefit from the timing retard with the bottle? Let me know , thanks ---
Old May 26, 2006 | 05:04 PM
Grims's Avatar
the MAP is only for subercharged applciations, and yes you should retard timing on the bottle.
Old May 26, 2006 | 05:08 PM
The 6cd doesnt say it has anything but START UP timing retard. Can you add a retard switch or should I run the MSD 6 btm (can you add a window switch)?!
http://store.summitracing.com/partde...5&autoview=sku
does it matter if its digital or analog?! ---
Old May 30, 2006 | 12:29 PM
nfa's Avatar
nfa
I was happy with the performance of my mallory 685.. until it decided to quit on me coming home from work a few months after install! Smoke started coming out of the unit... I need to send it back to Mallory. Anyone know how much they charge to repair a shorts on the mainboard? I bought it new in box, but from a guy on this board, so I dont have a receipt.
DirtyDaveW
Dec 1, 2016 05:37 PM
Heathen1
Jan 2, 2016 04:27 PM
warmeck
Feb 2, 2015 12:44 AM
Jul 4, 2005 05:00 PM
x7x7
Aug 15, 2002 06:49 PM
