Fittings??
Old Jan 7, 2006 | 09:22 PM
"White Knight"'s Avatar
Fittings??
What is the difference between AN and NPT fittings?
I need to know what type of fittings to buy and where I should get them from. I need a 90 degree fitting for the N2O inlet of the main line from the bottle that will enter the bottom of the NX "iceman" solenoid which fitting would i need? I also need a 45 degree fitting comming out of the bottle before the main line, what fitting would i use there?
Old Jan 8, 2006 | 02:17 PM
HarrisSpeedWorks's Avatar
Re: Fittings??
The AN style have a radius edge on them where as the NPT are straight cut. AN style will self seal, you don't need to use Teflon paste on them. NPT style fittings will need Teflon paste on them. Take a look at this link:
http://www.harrisspeedworks.com/shop...cat=342&page=1
The top of the fitting is AN, the bottom is NPT. Going into your solenoid will be NPT. Gonnecting to a hose will be AN.
Hope that helps a little.
Matt
Old Jan 8, 2006 | 10:38 PM
Re: Fittings??
Okay i think i got it, anything that screws into the selinoid is NPT and the rounded end that attaches to the stainless lines is the AN side.
Thanks Matt.
Old Jan 9, 2006 | 01:51 AM
383LQ4SS's Avatar
Re: Fittings??
one small thing to remember. Make sure when you buy AN fittings its a 37 degree flare. It seems everyone has only 37 degree flares now and that should be the standard. But you will still see 45 degree stuff in Jegs and Summit and a few other places.
The degrees is the angle of the taper on the tip of the fitting on a male fitting or the innder angle on female fittings.
Old Jan 9, 2006 | 10:28 PM
Re: Fittings??
thanks,
yea that could cause some sealing problems.
Old Jan 12, 2006 | 10:56 AM
Re: Fittings??
Any brand better than another?
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
