Why can't I see my purge?
This may be a simple answer but my car has been sitting since November in my garage. I just installed a 90 degree brake fitting with 2 outlets from my purge solenoid.I then ran the lines out the front of my nostrils on my glasstech hood..lol..but anyways when i tried it out i could see the n20 in a white form...it blew all the way to the top of the celing out of both tubes...looked really sweet...then about 30 min later i brought the camera out to take a picture and when i pushed the button all that happend was the loud hissing sound...could not see any white n20....why is this...the garage is only heated from a space heater so it was probably 40-50 degree...kind cold...but can you tell me why this is
....thanks
....thanks
Re: Why can't I see my purge?
Why would it still hiss so bad then if I was out...just pressure? My bottle was cold when i tried it the first time tho....i dont know...guess i'll wait till summer
1slowformula's right, you're out of dope. You'll be surprised how much "gaseous" nitrous is still in the bottle. The white you saw was the last of the "liquid" nitrous.
You can still use the pressure to test fittings and solenoids for leaks.
Ya i have picture but i dont know how to post them....im pretty sure the bottle wasnt even close to full....how do i post picture on this thing...thanks
probably wont have the actually purge pic of it coming out until spring cuz i wont fill the bottle till then...unless i get impatient which will probably happen.
14
Aug 11, 2015 12:03 PM
