383 high compression... nitrous?
Old Jan 27, 2006 | 08:25 PM
96LT1TX's Avatar
I am about to build a 383 w/ an Eagle 4340 forged crank, Eagle 6-inch 4340 H-beam rods, and Wiseco flat-top 2618 forged pistons. The assembly has been internally balanced, and is ready to go.
The block is freshly machined LT1 block and here's what's done to it
- Hot tanked
- Decked .005 in the hole
- Bored .030 over
- Honed
- Align bored and honed with Pro-Gram four-bolt caps
- Clearanced for a 3.75-inch crank
12:1 compression ratio
how much nitrous can I run in this? any?
Old Jan 28, 2006 | 10:08 AM
MEAN LT1's Avatar
Re: 383 high compression... nitrous?
Sounds like your thinking N2o is like running a blower or turbo. But in retrospect Nitrous loves compression. Too be honest it all depends on how fast you wanna go. Start off with a 100 shot and work your way up.
Old Jan 28, 2006 | 11:56 AM
96LT1TX's Avatar
see thats what I have been reading... when I first learned about nitrous I thought people wanted low compression to run it?
100 shot i think is first
Old Jan 28, 2006 | 01:05 PM
n2oCamaro's Avatar
12.8:1 here and planning on a 200 shot in the spring.
Old Jan 28, 2006 | 04:10 PM
drivefast4fun's Avatar
the bosses 77 Nova with a 383 is running 13.8:1 and a 250 shot!
Old Jan 28, 2006 | 05:51 PM
SantaCruz163's Avatar
You can get away with more than a 100 shot especially if you are running forged internals. If it was me and I was in your shoes, I would make sure I have a supporting fuel system and run a 200 shot to start and wouldn't look back. Heck, there are stock shortblock guys running that much nitrous with little/no problems. Just be smart about it and don't lack on the safety equipment: WOT switch, window switch, etc.
Old Jan 28, 2006 | 08:18 PM
63SSNOS's Avatar
I broke the main webs out of a 010 GM block with a 375 shot. It was a 13-1 388cu.in sbc witha 252@.050 duration cam. I run a dart lil M now an spray 350 no trouble with a 272deg@.50 heavy use, multi-stage nitrous cam, runs low 9s@150+. I think the lil M would take a lot more but ya don't know till its too late, thats the bad part, what I spray may blow your hood off at the 60 ft marker???? Work your way up an read those plugs!!!!!!! every combo is very differant, the cam grind has a lot to do with your motors ability to make power with differant amounts of nitrous.
Old Jan 28, 2006 | 08:32 PM
ze doktor's Avatar
you can get away with running a considerable amount of nitrous as long as you pull timing accordingly, and on a high compression motor getting the timing correct is more important than on a stock motor since you're margin of error has been significantly decreased. it's not difficult, just don't get greedy with the timing.
Old Jan 28, 2006 | 10:58 PM
CamaroSS30thAnn's Avatar
its easier to make more power with less of a shot with low compression motors cuz most of the time u are running some sort of FI (blower or turbo), it decreases the air temp and makes alot more power
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
