Accidentally Ordered a 125 shot...
Old Mar 30, 2006 | 11:32 AM
johnny3986's Avatar
Alright, I screwed up my order on Summit and an going racing regardless, but depending on the answers from this board determines whether I am going to be getting N20 times, or just N/A times.
I accidentally ordered a .057 and a .035 jet so I would be running a 125 shot. I NEEDED a .052 jet, but I refuse to pay $15 ($5.95 then $9.50 shipping) and the smiple fact is that it won't get here by the time I go racing.
SOOOO....here is my setup:
NGK TR-6 plugs...
NX FPSS
Bottle Heater
WOT switch
Window set from 2800-5500
Stocker fuel pump with 70K on it, and I do have an electronic fuel pressure gauge inside my car to monitor, but I know it prolly won't help out at the track.
3 or 4* of timing was pulled (but let's say 3) and the spark advance was tuned out on my PCM. (it is the 100 shot PCM4less tune...)
IS 125 SHOT SAFE FOR THIS?!??!
Old Mar 30, 2006 | 02:46 PM
OffspringZ28's Avatar
Re: Accidentally Ordered a 125 shot...
you'll be fine.
Old Mar 30, 2006 | 04:41 PM
johnny3986's Avatar
Suh-weet!! Anyone else??
Old Mar 30, 2006 | 04:49 PM
2000GTP's Avatar
You look good to go, you may want to upgrade to a Mallory box or something similar in the future so you can pull timing only when you spray. That way when you run N/A, you will not have to sacrifice power.
Old Mar 30, 2006 | 04:58 PM
T/A lt1's Avatar
Don't worry I sprayed 150HP with a Hotcam/stock LT1 and ran 11's with no problems. My fuel system currently that went 9's only consists of sock intank with a NOS 255 inline with adj reg for fine tuning. I have a FP gauge on the cowl of my car (under the 4" VFN hood) to keep an eye on things. I am putting a N2o fuel cell for the dual stage 150/150 I plan on running soon. Later Clint Later Clint
Old Mar 30, 2006 | 07:48 PM
johnny3986's Avatar
Thanks you guys!! Can't wait for the times!!
I DO have a stock rear end and am not planning on spraying off the line. I don't have slicks, but my tires are fairly new 275's....
Should I just lock-out first gear (it's a M6)???
Old Mar 30, 2006 | 11:38 PM
Daniel6718's Avatar
probably...need some m/t d/r
Old Mar 31, 2006 | 01:31 AM
johnny3986's Avatar
Wouldn't some drag radials just rip my rear end to pieces? Or would launching with slicks but WIHTOUT nitrous help out?
Old Mar 31, 2006 | 02:05 PM
launch on DR's without nitrous. lay into the nitrous once you hook
Old Mar 31, 2006 | 02:40 PM
crAzy95z28's Avatar
if i was you, i would not ever have my nitrous come on before 3k. At least set it at 3k activation.
mine is set at 3k-5800
Old Mar 31, 2006 | 03:09 PM
johnny3986's Avatar
Crazy, I haven't even shot the N20 yet, so I will reset it. Does it just cause the motor to bog down or is there a more detrimental effect?
Old Mar 31, 2006 | 04:38 PM
crAzy95z28's Avatar
thats alot of compression at low rpms... you could go BOOOOOM, under 3k rpms if u spray enough. Specially trq also, may even break something else besides ur motor.
Old Mar 31, 2006 | 08:39 PM
johnny3986's Avatar
Sounds compelling enough to spray at above 3K rpms.... lol
Old Mar 31, 2006 | 10:06 PM
2000GTP's Avatar
If you want to keep that Moroso CAI in one piece and on your car, then yeah..
Old Mar 31, 2006 | 10:23 PM
johnny3986's Avatar
I have a pretty stock motor...soooo....3K to say 5600 sound good??
