Vortech Elbow and Dry Nitrous 125hp ZEX???
Old Jan 31, 2006 | 01:57 PM
AlwaysCode390's Avatar
Exclamation Vortech Elbow and Dry Nitrous 125hp ZEX???
I have a vortech elbow on my car and recently purchased a 125hp shot of DRY nitrous from ZEX for my LT1. Can I drill BEHIND the dividing wall ( there is like 3" without the divider in there ) , or even in the rubber mounting point before my t.b. or before the maf?! Is it better to put the nitrous nozzle CLOSER or FURTHER from the T.B.?! Thanks A TON!!!---
Old Jan 31, 2006 | 08:04 PM
Re: Vortech Elbow and Dry Nitrous 125hp ZEX???
Anyone run this??? Or can anyone atleast tell me if its better to have the nitrous further or closer to the Throttle Body? Thanks---
Old Jan 31, 2006 | 08:54 PM
Nitro Dave's Avatar
Put the nozzle right in the elbow before the throttle boy. You can just drill and tap it. It will work fine.
Dave
Old Feb 1, 2006 | 10:07 AM
It will be fine even with the splitter down the middle of the Vortech, I am guessing it will be close enough to the t.b. it wont matter right? THANKS SO MUCH---
Old Feb 1, 2006 | 10:34 PM
Nitro Dave's Avatar
When the air stream makes it through the throttle body and flows into the intake plenum the misxture will be mixed into the air stream fine.
I use to worry about that two. But It works fine.
Dave
Jeff1904
Jun 5, 2016 05:00 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
95blkss
Sep 22, 2015 03:18 PM
Boss002
Jul 24, 2015 10:47 AM
