Next mod
Next mod
I have a 98 ss with the m6 and am looking for my next mod. I already have the loudmouth, ftra, pro-5 shifter, cags and am getting the texas speed and performance lid. What do you think my next mod should be. I was thinking ported mass air flow sensor ends or pulleys. Does anyone have any track results or hp gains with these. Any other mod suggestions would be great. I dont want to dip into the engine yet. Just some mods that will give me some nice gains for cheap, well not cheap, but decent price.
thanks
sweet98ss
thanks
sweet98ss
get a filter for the lid, you can port the mass air sensor but it wont make a difference till you get some serious mods in. You can always descreen and that will help a tiny bit. Next mods for you should be headers, gears, and a set of good tires. You may want to consider a predator programmer too.
I forgot to mention that I have a K&N filter too. I would like to get the predator but I dont think they make it for my year car. Do you guys have pulleys. How good are they. Any track gains. Ive heard mixed results from them. I am thinking about 4:10's because my rear is starting to whine. I know I can run alot better with some tires. One time slip I almost hit 108. This was before the ftra and the lid. How much will I gain form the ls6 intake. Thanks for the replies .
Get ASP underdrive crank pulley, GREAT MOD. With just the pulley, air lid and ported maf I dropped 4 tenths in my quarter and gained 4 mph. It's a nice mod, and you are right, the Predator is not made for 98s. By the way, the porting of my maf ends leaned my car out really bad, luckily I got it dynoed and fixed the problem with the predator, so I wouldn't suggest porting the maf unless you have something to fix your afr. So in other words, get the asp pulley. It will drop at least a tenth in the quarter and add at least 1mph.
Sweet . I assuming you didnt do the alternator pulley because your car is an a4 right? Ill have to search around for the best price on the pulleys. I think there on backorder now though. Any other mods you suggest. I am in need of some tires right now but Im not sure what kind. I want some cheap ones. I got through them pretty quick. I have kuhmo's right now. I can get them for around 475 shipped to the door.
Yeah, that's why I didn't get the alternator pulley. Try www.ls1speed.com for the pulleys, they had them in stock a few months ago. You also won't want the pulleys if you have or are getting an aftermarket system. As for tires, I ordered some Eagle F1's, the ones that come stock on the SS, from a place called Lesschwab tires. I believe the address is www.lesschwab.com, the tires were really cheap, only $89 for each one, they are normally over $200.
CARiD
Jul 7, 2015 08:19 AM
