LS1 won't start
Old Apr 15, 2003 | 08:22 PM
scottmech's Avatar
LS1 won't start
Got a 98 Z28. Was pulling out from a light and felt the car act like it was running out of gas. Looked at the gas guage and saw I was on E. Couldn't make it to the gas station before the car quit. Put 3 gal of gas in it but it still won't start. Gas guage now reads 1/8 tank. Took the cap off the valve on the end of the fuel rail. Doesn't seem to be any pressure there.
Are there any tests I can do on the fuel pump to see if it's working? I remember being able to jump some teminals on the older f bodys to turn on the pump. Didn't know if there was something similar I could do on the LS1's.
Any help appreciated.
Old Apr 16, 2003 | 12:04 AM
Bone Maro's Avatar
OUr fuel pumps need fuel to keep cool while running. Hitting empty drastically increases the chance of frying the pump, and that's what it sounds like you did.
Turn the key on, but not to start. Listen for the fuel pump to prime(whining sound). Go from there.
Old Apr 16, 2003 | 12:50 AM
stik6shift98's Avatar
sounds like the pump is gone
Old Apr 16, 2003 | 12:52 AM
ZIPPERR's Avatar
An easy test is spray starting fluid in TB and turn her over. If she starts you know the fuel pump is shot.
Old Apr 16, 2003 | 02:16 AM
Gossco95's Avatar
fuel pumps dont like it when you run low on gas.... 1/4 tank is my limit I will go until I hit the gas station again .....
Old Apr 16, 2003 | 07:15 AM
scottmech's Avatar
I normally fill up at 1/4-1/8 tank, but my mind has been preoccupied with other things lately.
Will try what you said and let you know what I find.
Thanks again.
Old Apr 16, 2003 | 09:56 PM
scottmech's Avatar
Shot some starting fluid in the TB and it started.....then died. Also listned to the tank (from underneath) while the wife turned on the ignition......couldn't hear anything. Looks like its the pump. Thanks for the help.
Old Apr 16, 2003 | 10:02 PM
ZIPPERR's Avatar
Fuel pump for sure.. Glad I could help
Old Apr 17, 2003 | 12:16 PM
scottmech's Avatar
Replaced the pump this morning. Car started and ran fine but the SAS light was on. Reset the ECU and everything seems to be fine so far.
Thanks again for the help.
Old Apr 17, 2003 | 12:42 PM
u mean the SES light right.....get the code checked out at autozone for free
Old Apr 17, 2003 | 02:59 PM
scottmech's Avatar
Ya......the SES light. Brain fart on my part. And speaking of that..........
The SES light came back on. Code P0449, EVAPORATIVE EMISSION CONTROL SYSTEM VENT VALVE/SOLENOID CIRCUT MALFUNCTION.
If I reset the light, it stays off the very next time I start the car. But the second time I start the car after resetting, I get the light.
Anyone have any ideas on what it could be??????
Thanks.
Old Apr 17, 2003 | 03:18 PM
scottmech's Avatar
Nevermind. Went back under the back of the car to double check my work and found a connector I didn't hook up. It's all good now.
Old Apr 17, 2003 | 03:32 PM
good good
i hate when u forget to do stupid stuff like that
Old Apr 17, 2003 | 10:20 PM
crazyz28's Avatar
same sh#t happened to my 98 Z28, ran out of gas, nerver started again, dealership replaced the fuel pump -- thank god for extended warranties
eazyZ
Mar 1, 2015 07:12 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
