what are the common ls1 problems?
i've had an lt1 for quite a while now and was looking into an ls1. what are the common problems with them? or any problems that you have had. lt1's have the opti, and oil leaks. thanks.
piston slap, oil consumption for newer models, warped brake rotors, leaking pinion seal, slow passenger side power window,
i have leaking pinion seal but i replace my fluid yearly so it doesn't matter...very tiny leak.
the power window thing doesn't bother me at all.
I just had the rear pinion seal changed this week. Haven't had any squeeky belts yet. Rear driver side brake squeeks when I'm driving slowly though a neighborhood. Other than that and a dash board rattle I'm sitting pretty good.
but RWD is awesome most of the time!
