a-pillar gage pods and gages
just curious...
what extra gages do you guys typically have? oil temp, a/f, ?
also, how difficult were they to install? i understand the mechanical version of the fuel gage can be a little annoying...
I run a triple a pillar with an a/f at the top, a water temp in the middle and another a/f at the bottom. the a/f gauges are connected to both pre-cat O2 sensors. the water temp is not yet hooked up due to the sending unit not fitting in the head of the car. Also, yet awaiting for someone out there to tell me how to hook it up, but it appears no one would like to share that knowledge, an installuniversity isn't helping either.
I run a dual pod with A/F and water temp. I had them installed at a shop. $100 and I didn't have to touch anything. I would really like to get an oil temp gauge as well.
~~SPEEDY,, I will tak a pic of where the installed the temp unit for the water, it'll blow your mind
Flare65
Aug 19, 2002 04:14 PM
