Rearend Question
Old Apr 14, 2003 | 10:13 PM
dj haf's Avatar
Rearend Question
how much torque and hp can the stock rear end take, and how much can a 12 bolt take? and which 12 bolt is better, cuz i've seen the strange and the moser 12 bolt but i have no idea which one to go with when the time is right... thanks guys
Old Apr 15, 2003 | 10:13 AM
antta99's Avatar
Do a search on the different rearends.I broke my stock axle with just ET Streets. The car was basically stock.It also depends on what you are gonna do with the car. No slicks or drag radials and you could get away with the stock rear. Any type of sticky tire and hard launches and your running on borrowed time.
Old Apr 15, 2003 | 12:18 PM
norcalstreet's Avatar
It depends. There's people doing 11 seconds on a stock 10-bolt. It's more of a matter of how you treat it as opposed to the amount of HP it'll take. The 10-bolt can break at the stock HP level of an LS1. Using slicks is almost a guaranteed way to break your 10-bolt rearend. Dumping clutches doesn't help either. Sends to much shock to the rearend.
Moser seems to be the 12-bolt rearend of choice for LT1 users. I once read that they're good up to 1000 HP but that's really isn't here or there. Although they'll take more abuse it's really a matter of how they're treated.
blac94Z
29
Mar 25, 2015 04:21 PM
ddr698
Jan 31, 2015 10:58 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
