Cooling fan mod
Old Apr 7, 2003 | 12:35 AM
BadAndy743's Avatar
Cooling fan mod
I did the cooling fan mod yesterday in about 30 min. My switch now operates the fans at low speed. The only thing is, the instructions I was using showed how to operate the fans at high speed as well, but it would throw a code. Does any one know how to wire it to operate bothe fans at high speed w/o throwing a code? How long does the battery last like this by the way? Thanks alot
Bad Andy
Old Apr 7, 2003 | 11:35 AM
rncotton's Avatar
I've seen a way to do that, but I'll have to dig through and find it. I do remember that the wiring was done at the connector on the passenger side of the top of the wheel well under the hood.
Old Apr 7, 2003 | 12:39 PM
stik6shift98's Avatar
did u buyt the slp fan switch or did u make your own...???
Old Apr 7, 2003 | 02:57 PM
BadAndy743's Avatar
I made my own. Piece of cake. Didn't even cut the harness. But I want to use both fans at high speed. I know that I can jumper relay 1 and two to run them in series, which runs them at high speed, but this throws a code. Help!
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
grabbem88
Apr 16, 2015 06:57 PM
