2002 Cam is different?
Old Apr 6, 2003 | 06:52 AM
96Z28man's Avatar
Are the 02 cams different then the 98-01's? If so, what is the difference?
Old Apr 6, 2003 | 07:31 AM
nikkev's Avatar
I "think" that the '01-'02 cams are the same.The '98-'00 LS1 had a bigger more aggressive cam and the '01-'02 LS1 got a smaller cam that was made for emissions to delete the EGR valve.It's not really that big of a difference though.I do not know any of the specifics of the 2 cams,sorry.
Kevin
Old Apr 6, 2003 | 07:52 AM
Zdriven's Avatar
nikkev,
I have documentation that the '99 - '02 use the same camshaft.
Part # 12560965, I think the '98 was the same, but can't
confirm.
The specs for the cam:
.500" lift intake and exhaust
200 deg intake & 208 deg exhaust duration @ 0.050"
Hope this helps.
Old Apr 6, 2003 | 08:44 AM
nikkev's Avatar
Originally posted by Zdriven
nikkev,
confirm.
Hope this helps.
Then how did the '01-'02 get rid of the EGR?I would love to get rid of mine.
Old Apr 6, 2003 | 09:07 AM
Zdriven's Avatar
nikkev,
It was the way that the federal regulations are handled, I don't
know all the details. I do know that we (GM Powertrain)
recently eliminated the EGR on almost all the V8 (GEN III)
applications. EGR currently is used in only a couple of the
trucks.
I've also been told that EGR will probably come back in the
next couple of years to meet the ultra low emission regulations
comming out.
Again I don't know all the details, I think they were able to
handle the emissions with different calibration and better
cats.
Old Apr 6, 2003 | 09:15 AM
nikkev's Avatar
nikkev,
trucks.
comming out.
cats.
Cool thanks! So I should be able to remove mine on my 1998 Z and have no problems other than the SES light (until a computer reprogramm) correct?
Old Apr 6, 2003 | 10:08 AM
BigBake's Avatar
98-00 LS1 dur 202/210 lift .496/.496 w\ 116LSA
01-02 LS1 dur 198/197 lift .478/.478 w\ 115LSA
Bigger change than you think.
Old Apr 6, 2003 | 10:16 AM
Capn Pete's Avatar
Those #'s look good to me (well, accurate, not "good". "Good" would be >.500" lift!!!)
Old Apr 6, 2003 | 10:51 AM
96Z28man's Avatar
man that sucks, that 01-02 cam IS alot smaller.
Old Apr 6, 2003 | 11:15 AM
Zdriven's Avatar
Those latest numbers are more accurate than what I mentioned
before, sorry to mislead you. I was looking at a chart for the
Austrailian engine which shared the cam with the F-car until
'01 when the F-car switched. I didn't catch that first glance
at the chart.
Oh well, everyone makes mistakes, I'll admit mine here.
Didn't mean to cause any confusion.
Old Apr 6, 2003 | 11:49 AM
danziger's Avatar
Talking
Yeah, the smaller cam in the 01-02s offset the bulk of the increase from the LS6 manifold. However, the newer cars torque and "power under the curve" are excellent.
Old Apr 6, 2003 | 01:38 PM
nikkev's Avatar
So you're saying that putting the LS6 intake on a '98-'00 will make more power than a stock '01-'02 since we have the larger cam?
Old Apr 7, 2003 | 02:05 AM
Aklaim's Avatar
Yes. And LS6 intake on a 98-00 car will yield better results. The 98-00 cars have a larger cam. You can buy a LS6 mainfold from SLP that has the egr provisions for the 98-00 cars. Some people have put 15+hp at the rear wheels with just that manifold alone. Weiland has a new aluminum LS6 intake that can be ported to all hell. A few guys were saying how a well ported intake was showing relsults as high as 35 hp at the rear wheels. And that was just intake alone. This was also on a 98-00 car.
C6LS3
Apr 15, 2015 09:50 AM
QuickSilver02
Apr 7, 2015 11:12 AM
feistersLs1
Mar 12, 2015 12:49 PM
mspennyhughes
Mar 1, 2015 03:50 PM
