i wanna spray, what plugs
Old Nov 11, 2002 | 03:46 PM
EV71468's Avatar
I've got a 468 big block runnin in the 3000- 6500 range. I'd like to spray a 150 shot, but i don't know the proper plugs to run. i called the Edelbrock tech line, and some hick basically told me he didn't know. some techline. if anyone has any info it would be much appreciated. id like to run a champion. thanks.
Old Nov 12, 2002 | 07:46 PM
406Camaro's Avatar
What heads are you running?
Old Nov 12, 2002 | 08:30 PM
EV71468's Avatar
049 oval ports, ported, 2.30, 1.88, valves, open chamber.
Old Nov 13, 2002 | 05:36 PM
Guido67SS's Avatar
nos
Run plugs that are 2 steps colder than you normally run. I ran Champion V59C in by BBC. Run 32 degrees advance and race fuel. Make sure you have a dedicated fuel pump and dedicated fuel line to feed your nos. Use a window switch to keep nos from spinning your wheels the first 10 feet, or from sprayin above 6000. I am asuming 3.08 gear. You should be able to spray all day long as long as you don't run lean. Fun stuff....
Old Nov 13, 2002 | 06:43 PM
EV71468's Avatar
GUIDO67SS
Thanks for the info, much appreciated.
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
Fatdog2
Feb 13, 2015 08:19 PM
David Dorris
Jan 17, 2015 08:10 PM
AutoRoc
Aug 7, 2002 11:45 PM
