1967 camaro sub frame help
Is there something wrong with your current subframe? You don't need to swap subframes to get disc brakes.
To answer your question, the Nova subframes from 68-? (not sure when) do bolt in, not sure about a four door unit. Should be the same.
Jody
Jody
Re: 1967 camaro sub frame help
Originally posted by vicki-ron
i would like to know what years nova sub frame will fit on a 67' camaro ?
thanx
vicki&ron
thanx
vicki&ron
68-74 Nova, Astre, Apollo... or 67-69 camaro or firebird will interchange
There are quite a few aftermarket builders you have bolt in front frames that use late model or mustang suspension components
I am actually looking to get rid my subframe - I had it sandblasted and powder coated black - it is in very good shape. In addition, I also have the upper and lower control arms (sandblasted and powdercoated) with new ball joints and poly-urtheane bushings pressed on - never used. Let me know if you are interested.
F'n1996Z28SS
08-23-2023 11:19 PM
CARiD
01-14-2015 04:00 AM
07-04-2005 05:00 PM
