hood clearance
Old Nov 20, 2002 | 02:29 PM
talos's Avatar
Talking hood clearance
ok well i have a 80' z clone and i have a 4" cowl, u can check out my photos at photos
ok but my intake and all that junk still is under where the stock hood would be... how could i go about rasing everything to get the aircleaner in the cowl? intake, carb, spacer, aircleaner
Old Nov 20, 2002 | 03:19 PM
Capn Pete's Avatar
Lightbulb
So what you're saying is that the hole is there in the hood for the air-cleaner to stick up through, so want to know how to get the air-filter to sit higher up from the engine into the hood???
Well, you could A) get a higher rise intake (such as an Edelbrock "Air-gap" intake which sits a bit higher due to the air "gap" design), B) use a 1" carb spacer, which will not only raise the carb & air-cleaner up an inch, but will also increase the HP & TQ of the engine (I read an article in a magazine that dyno tested ONE engine, with various intakes, both with and without carb spacers, and the spacer plates seemed to add power every time), and/or C) buy a taller air-filter. I've never specifically looked for one, but I'm sure at a speed shop is where you'd find those air-filters that are about 6" tall as opposed to the regular 3-4", so that would have it sticking up higher as well.
HTH
(BTW: check out the pics of the '73 in my sig................that car has an Air-gap intake on it, and although it may be hard to tell from the picture, it does sit a little higher than a regular intake).
Stephen68
Oct 16, 2015 03:50 PM
CARiD
Sep 30, 2015 05:44 AM
gearhead3
Parts Wanted
Sep 16, 2015 08:18 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
