t-56 flywheel
Old Oct 7, 2002 | 05:55 PM
camarosf's Avatar
t-56 flywheel
i need some info on putting a t-56 out of a 95 camaro into my 69 camaro. the main thing i need to know is what to do about a flywheel . i have a big block with a 4 speed in the car but i think it would be nice to use the 6 speed. any and all info would be greatly appreciated.
tkanks
billy
Old Oct 8, 2002 | 12:02 AM
Steve Spohn at Spohn Performance sells a kit to install the T56 in 3rd Gens, so perhaps he could set you up with something for your earlier model.
SPOHN PERFORMANCE
Old Oct 17, 2002 | 08:55 PM
camarosf's Avatar
surely someone can help......
Old Oct 17, 2002 | 09:01 PM
a) Did you check with Spohn?
b) Did you post this question on "Classic Tech" where you are more likely to get a reply?
Moving to Classic Tech......
Old Oct 18, 2002 | 11:27 AM
Teetoe_Jones's Avatar
Check this out:
http://www.pro-touring.com/t56/index.htm
Tyler
Old Oct 18, 2002 | 11:39 AM
texlurch's Avatar
Your main problem is the bolt spacing on the crank. The T56 flywheel is used on a one piece rear main seal crank, which has a smaller bolt pattern than the big block. I don't know if anyone is making a conversion flywheel
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
