M/T ET Street tire size question????
Old Feb 22, 2003 | 06:27 PM
JasonS's Avatar
Would 26x10.5-16 fit on a 95 Camaro? Would it screw up the gear ratio to much? I have the stock gear ratio 3.42.
PS, My Camaro has Eibach 1.8" lowering springs
Thanks for any info.
Old Feb 22, 2003 | 06:41 PM
RacinLT1's Avatar
Yes they will fit.might have to roll the fender lip since it is lowered.
Also they are about .5" taller than stock. So the gears will be slightly off.
Old Feb 22, 2003 | 06:43 PM
JasonS's Avatar
Thanks for the info!
SO a stock tire is 25.4" in Overall Diameter?
Old Feb 22, 2003 | 09:46 PM
rskrause's Avatar
Moderator
Last year I used the 26x11.5x16" on my car (with Eibachs). I cut off the corner of the leading edge of the rear part of the wheel well to be sure of having clearance when the tire expands at speed. But the width required no clearancing at all (on an 8" rim).
Rich Krause
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Ken Cemo
Jan 27, 2015 08:45 AM
Jason Short
Jan 19, 2015 06:33 PM
