traction
Old Feb 15, 2003 | 04:47 PM
lt4 fd's Avatar
traction
Ok lemme know if this makes sense... Since I dont hook up well with the stock shocks and hotchkis lowereing springs I figure I would get some different shocks and springs like maybe the global west front and rear adjustable ride height kits and some sort of adjustable shock absorberfor the rear. Adjustable rided height so I can lower down for looks and handling and maybe raise it up some and adjust the shocks the shocks for drag racing. Is there any way to do this for a grand about???
Old Feb 15, 2003 | 07:54 PM
TedH's Avatar
I don't see what type of tires you have. Tires are the first and best suspension modification you can make. A decent set of drag radials or ET Streets can make all the difference in the world. Then lose the front sway bar and just do the front shocks (loose).
Always take a good look at the starting line. Avoid shiny spots. Try to follow cars with slicks. Do a solid burnout. Work on the basics and find a good baseline before throwing money st suspension mods.
Old Feb 16, 2003 | 11:53 AM
lt4 fd's Avatar
A bunch of suspension stuff came on the car and I have nitto 555r's and cold they arent worth that much more than the eagle gs-c's I replaced them with, I have yet to heat them up and do a launch. Thing is I dont want to remove my sway bar since I want handling as well thats why I was thinking of the adjustable ride height.
Boss002
Jul 24, 2015 10:47 AM
Javi Fierros
Jun 10, 2015 03:35 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
brentasan
Jul 7, 2002 08:59 PM
Jay-mak
Jun 14, 2002 05:40 PM
