Motor plate mid plate?
Old Feb 26, 2003 | 04:48 AM
383 Blwn Bird's Avatar
I'm converting to a motor plate, mid plate setup.
I went with madman's front plate, as far as the mid plate I'm trying to decide which one? How did you guys install it?Any tricks?
Any pics? Any help would be great.
Thanks,Kevin
Old Feb 27, 2003 | 09:58 AM
Guido's Avatar
I have a motor plate but no mid plate. I installed an engine limiter rod that attached to the drivers side motor mount and tied to a piece of steel angle welded to the frame.
Ive seen midplates though and it looks to me like you could bolt the midplate in with the engine and trans and then set it in the car. Then, weld some brackets to your firewall to hold the plate in place.
Perhaps someone else will chime in here with some better advice.
good luck!
Old Feb 27, 2003 | 08:51 PM
Stephen 87 IROC's Avatar
I'm with Guido. Front plate only with limiter. I wouldn't even consider a mid plate in a full body car without having some sort of removable floor to be able to get at it.
I should take a picture of my limiter. I have a 3/8" tube with nuts welded on both ends. 3/8" Heim joints are threaded into both nuts. One end is attached to a motor mount hole on the drivers side of the block. The other end attaches to the underside of the frame under the steering box. There just happened to be a threaded hole there that I could use and it worked out perfect.
You need the limiter to keep the engine from going forward and backward. Motor plates will flex too much. You risk breaking the tailshaft on the tranny without one even if a poly or solid tranny mount is used.
Old Feb 28, 2003 | 03:28 PM
PatriotTA's Avatar
You really should take a picture I'd like to see your setup. I don't have anything right now, but I'll be making a motor plate this spring, and I'd like to see how your limiter is set up.
HectorM52
Jul 30, 2017 11:46 AM
alphaauto
Jan 23, 2015 07:42 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
guionM
14
Jun 19, 2002 08:30 AM
