- Good deal or not ???
- does anybody have acsess to ALLDATA
- Those with 1LE cars inside please
- VATS security system
- battery draw
- How much does a typical battery weigh?
- Loudmouth vs. TSP Rumbler
- Stupid Newbie Here!!!!!
- M6 Shift Knob Alignment
- anybody here work for a GM dealer need help
- mothballs up octane?
- voltage drop....
- Quick question??
- Impact for wheel changes
- Best remote starter for LT1
- big block chevy
- looking for a soundclip: LT1 w/ SLP 20TL & Headers
- Need help flushing heater core on 97 T/A
- Dyno an automatic trans car?
- Locks Freezing.
- Power Window Kits.
- 97 S10 Fuel Injectors
- early shifting?
- Question on previous owner using 87 octane
- digital cluster?
- Hood Scoop Grill Install?
- Improve a '99 SS w/ $1000?
- Unique Water Related Misfire?
- Painting headers with VHT paint?
- Can anyone suggest upgrades for my Z28?
- Dumped true duals + cats?
- can i replace my flowmaster muffler only?
- My Pacesetter Longtubes are RUSTING!
- removing seat base
- Engine Tape?
- battery dying question?
- 98-02 Key FOB on 1994?
- Small light in door
- Dyno info
- Gear drive sound clips? How loud?
- My Z wouldn't start today...
- Properly adjusting valve lash?
- Headlamp switch relay??
- 454 Possibilities?
- TIPS MAKE HUGE DIFFERENCE in exhaust sound
- LT1 Trans Am- No T-Tops?
- Door problem
- My new(???) AFR cylinder heads - WTF???
- Headers Or Headache
- New wiper motor installed, but wipers are acting funny...
- dr gas x pipe
- exhaust on '98 3800
- my car is ticking?
- removal of window knob?
- Where to buy a MAF?
- Rear Defogger Dead
- Turn signal/electrical problem?
- Slp Cold Air Intake Help
- Looking for part number
- not sure where to put this....
- Do I have an LS1? Just bought 2001 Z28
- cheat the E-check?
- need help, have questions about my new car
- New Interior Parts
- Changing out plugs
- Heater not working...?
- lt1 swap
- SSRA vs. FTRA which one?
- NGK plug advice
- heater problem
- Squeeky steering wheel. Thoughts?
- I hate my Sweet Thunders!!
- How hard is it to take the dash out?
- firebird headlight problem
- do i HAVE TO USE ajd panhard bar and some lca relocation brackets w/17x11's?
- 67 Camaro for SEMA Show Pics
- Anyone use Autometer Nexus gauges?
- Everything Is ****ed Now!!
- true dual exhast;whats involved?
- Value of 1994 B4C M6 with 53,000 miles?
- T-Top or Hardtop
- Exhaust System Info Needed
- new era performance
- engine bay cleanup
- straight 30 vs 10w30?
- 4.10 gears on a stock a4
- Cheapest place for Electric Fuel psi gauge?
- Fuel feed questions...
- found something in tailpipe
- NHRA Build Number
- SS Floormats
- NEED HELP: First Gen LS1 Swap
- Compressor hookup related (not car)
- Fan on and off temp
- Purolator Oil filter
- ticking noise from under rear seats
- HELP! 94 Z keyless entry won't work
- Dipstick Removal
- Air Bag Light Came On
- What is an old police special (B4C) worth ??
- How do you tell if your EGR value is bad?
- Can this be done?
- Speedometer Swap 95 to 2001?
- Where is the best deal on weatherstripping?
- Weird Smell!!!!
- Bad Sounding Audio in My Z28
- Changing window regulators - need advice
- Spring found from door.
- Window mechanism broken, not motor related.
- Circuit Breaker
- How do I change my LT1 T/A headlights?
- Exhaust dilemma
- 98 SS hood
- Weird sound during cold start up.
- Wolf's Head Oil
- Steering Wheel Split
- which plug wires?
- Camaro turn signal flasher fuse
- Just picked one up
- Need Some Major Advice!!!
- Dropping in a new motor in my Yukon?
- 3" Collector flanges...Where can I get these
- Maintaining headers - how?
- Where is the fuel pressure switch that primes the pump?
- Rear window defogger playing up
- FTRA Question
- Storage?
- Vibration and noise on left turns and high speeds
- How do you like your moroso spiral flows?
- anyone ever buy from redlineperformanceengineering.com?
- Why are my back seat speakers not working with my Alpine head?
- What would you do to store your vehicle for 3 years?
- Opinions >> SLP ECM PROM ?
- how to use a slim jim on 94 Camaro??
- Turn Signal Release Spring Question
- Idle speed Vs Emissions
- Racetronix Pump & Harness Installed!
- dart pro 230's
- LT1 or LS1
- info on 85 iroc-z
- Door sagging/interference problem
- Troubleshooting vibrations
- Winterizing!!!
- not sure how to do this need help
- anyone have a wiring schematic for the cruise control circuit in a '94 Z?
- Borla XR-1 vs Loudmouth
- need help thinking about buying a 95 firebird have questions
- 99 Intermediate shaft fit in a 94?
- how do you get the stock auto knob off???
- Tilting the Steering Wheel?
- Manual Seats to Power Seats
- Looking for more HP!!!
- cool site for tracking auto build/restoration projects
- headlight problem...
- headlight problems...
- Hood insulation
- Small electrical problem
- pass compartment air filter??
- Disableing A/C. wires to snip?
- Ignition module Stock,accel,msd which one? How many pins do I have?
- Rearview Mirror
- Both power outlets dead...
- How do you pay for this??!
- LT1/LS1 Lifters
- Anyone running Earl's Braided Brake line kit???
- Storing car for winter, what to do?
- blinker problem
- Use gasket sealer for head gaskets?
- Power Window Motors on Camaro
- crash door bar removal, how did you get it out???
- Battery Light When Raining!
- Console Latch
- Triple Gauge Pods on 94
- changing steering wheel on 4th gen
- Ahh winter
- smokin
- whats a good price
- Pacesetter customer service.
- Window Track/Tray Problems
- combination motorsports...
- Automatic window function.... Broke?
- could my battery be causing this?
- Fan's arent turning on, any ideas?
- Loctite question
- Check this out!
- Speed Density cars slower then MAF?
- tips and tricks for removing exhaust manifold bolts
- ZL1 questions
- Best way to get money back out of car
- Header Piece Bent
- Where to Replace Exhaust Bolt?
- Yours to download - head and cam spec charts.
- YESSS!! I'm an idiot
- Spark plug boot
- anybody running a pre-filter?
- First post some questions
- I cant go to madz28.com...<meta name="description" conte
- Steering feels strange
- optispark
- F-Bod Trouble Shooters: INSIDE!!
- Door Lock Switches
- Does this sound about right?
- "Clunking" window
- Is anybody using the product called Scangauge?
- Tunnel brace
- Driver Side Floor Pan
- LLoyd Elliot's web site?
- Any good Mechanic's message boards?
- Dyno'd today...
- Interior Lights Flicker When I Hit a Bump??
- 350 balancer ona 327
- 4" mufflex catback
- Need quick help...my car doesn't want me to race...
- Collecters?
- Headlights and Fog lamps ???
- Camaro reborn: 700-horsepower
- Does SLP Traction Control module fit a 96 Z28?
- Replacing the Seat Belt Guide on Drivers Seat
- G35 vs. My Car
- Fuel pump install???
- Cluster Keeps Resetting?
- plastic windows
- Hitting Dyno Tomorow. Need Tips.
- Things to not do to a keyless remote
- TCS swap from another car?
- Need Exhaust/Muffler Help
- Light bulb info for Trans Am
- Loose Pulley
- parts
- 96 camaro factory manual question
- taillight ??? what is it.
- Opinions on synthetic in a 3.4 Hi Mileage
- 97 Window problem.
- noticing smoke..what could it be??
- Custom dash light question
- Can someone tell me what these wires could be?
- Removing Foot Well Panels
- DS safety loop with duals?
- Windshield Wiper Linkage Questions ???
- Crazy exhaust idea for 95 LT1: is this possible?
- "Restore" engine treatment? Plus a question on Lucas motor oil....
- new y-pipe for my Y87, would one from a 2000 Z28 fit?
- Headlight Dimmer Switch is HOT
- Heater bypassed?
- the infamous VATS problem? or ??
- car won't idle/over heating
- slp ram airbox question
- LQ9 Heads
- Rotten gas in tank?
- Racetronix....
