Idle speed Vs Emissions
Why does a low idle speed produce more exhaust hydrocarbons than compared with a fast idle?
I would have assumed that the air/fuel mixture would have more time to fully combust at a low idle and therefore putting out less HC, but apparently not. This effect also seems apparent in cammed cars.
How does this also effect the amount of Carbon Monoxide emissions, a low idle produces a high percentage of CO but a fast idle produces a negligable amount?
Anyone know why?
Anyone know why?
Re: Idle speed Vs Emissions
Would the faster intake/exhaust port velocity of a faster engine speed not exaggerate this effect?
I would have thought intake/exhaust scavenging would be virtually non existent at idle because of the low speed of the exhaust gas.
Assuming you are right, what difference does engine speed have on scavenging?
Originally Posted by flatlander757
I'd imagine it is directly proportional because you don't need scavenging at lower rpms and the pulses only move as fast as the engine is putting them out.
This can't be the case though as the gereral results disagree with me.
Well if anything I'd think it mainly reads higher because the valves are open longer than at higher rpms. So since it is able to draw in more air at lower rpms than compared to high rpms, the O2 sensors should tell the PCM to dump more fuel in.
I dunno, Thank God my 94 doesn't need smogged
