NEED HELP: First Gen LS1 Swap
I recently ran into deal that cannot pass up. a buddy of mine wants to put a carburated motor in his 99 camaro and i want his ls1. i have a 68 camaro with a muncie 4 speed. he is giving me everything from the fuel pump to the radiator including the pcm and wiriing harness.
First: is this do-able with out spending too much?
Second: what problems did you run into?
Third: does the muncie 4 speed bolt up to the bell housing? (if not i can most likely make something to fit the application)
Any info will help. thanks
-kelly
-kelly
Jul 4, 2005 05:00 PM
