Where is the fuel pressure switch that primes the pump?
Old Nov 22, 2005 | 06:34 PM
chevroletfreak's Avatar
I am installing a new pump, but now that it is wired up it is still not working. My battery is almost dead so hopefully that is the reason. Just in case, I would like to know where the fuel pressure switch is that turns on the pump.
Old Nov 22, 2005 | 08:50 PM
OBE1 95Z28's Avatar
Re: Where is the fuel pressure switch that primes the pump?
From Shoebox's site:
http://shbox.com/1/4th_gen_tech2.htm...essure_testing
Old Nov 22, 2005 | 09:14 PM
The only thing I found on his site was the prime connector. I will deffinately test using that connector, but I would still like to know where the relay or switch is that turns on the pump.
Old Nov 22, 2005 | 10:11 PM
The fuel pump relay is listed in the component location views. The PCM operates the relay.
Old Nov 22, 2005 | 10:29 PM
The PCM turns on the fuel pump (via the relay) when you turn the key to the run position. If you do not start the engine, the PCM will not "see" the low resolution pulse pattern from the Optispark, and will turn the pump off after about 2 seconds. It will not run again until 1) you start the engine, or 2) turn the key off and turn it back on.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
