changing steering wheel on 4th gen
Re: changing steering wheel on 4th gen
Its not really complicated. You remove the airbag, remove the stock wheel with a puller, install the new wheel's hub and then the new wheel. Then you will have the airbag light in the dash lit and you can cut the wire to turn that off.
Its pretty easy to do, I have a Grant GT wheel with a billet adapter on mine.
I had the cluster out and just removed the bulb to get rid of the lite.
You could measure the resistance of the air bag and then put that size resister in the connector. That way if you get in a accident the passenger air bag still goes off.
If the air bag system detects a fault neither air bag will go off in a accident.
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
