Heater not working...?
Old Nov 30, 2005 | 11:02 AM
95_z28_4_Ivan's Avatar
Well here's the story. It all started cuz my A/c was not funtioning, it was blowing air, but just hot air. So I went to a local shop a had it refill. So it worked just fine after that. But now that it's time to use the heater, it only blows cold air?? I kind of wanna try to fix it my self, so if you folks could give me any ideas as to where to begin. I would appreciate it.
Old Nov 30, 2005 | 01:13 PM
Re: Heater not working...?
The most common cause of no heat is a clogged heater core. Remove the heater hoses at the water pump and flush both ways with a garden hose. Keep moisture off the opti.
Old Nov 30, 2005 | 02:04 PM
MyShibbyZ28's Avatar
YOU do not know what you are talking about
What I did instead of taking it off at the water pump, I took it off at the firewall. Then took some 1/2" and I think 3/4" tubing (because they are two different sizes) and ran a hose through it very slowly one way, with a bucket catching the mess on the other end. After an hour of flushing both ways it was clean and bam! I had heat.
Old Nov 30, 2005 | 07:14 PM
LqMth's Avatar
I just put the hose right in at the firewall. I flush it in both directions and a bunch of junk comes out. After that the heater is nice and toasty.
Old Nov 30, 2005 | 08:21 PM
94 TA TT2S's Avatar
I agree....Worked for me....
Old Nov 30, 2005 | 09:48 PM
That was constructive.
Old Nov 30, 2005 | 10:22 PM
What I described is the easiest/fastest way, IMO.
Old Dec 1, 2005 | 05:55 AM
Dave89IROC's Avatar
agreed, plus no risk of breaking the tubes off the heater core if the hoses are stuck.....
Old Dec 1, 2005 | 03:39 PM
Great advice !!
I'll definitely try that. I'm an early bird, I get up usually around 4 am(not by choice) and it's freaking cold. so hopefully this will take care of the problem.
Thanks.
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jan 23, 2015 01:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
