slp ram airbox question
Re: slp ram airbox question
The SLP online catalog shows the same part number for both the Ultra-Z and the Ram Air HO airboxes, and indicates it works with both hoods:
http://www.slponline.com/view_product.asp?P=100008
The SLP airbox is dimensionally identical to the stock WS6 airbox, lacking only the "Pontiac" and "Ram Air" logos, and does not come with the pre-molded gasket for the lid. They include some sticky-tape weatherstripping instead.
I've compared my SLP box to a genuine WS6 box, side by side, and they are identical, except as noted above.
i finally got my new airbox in and i already got rid of my old one. without the rubber peices on it it seems like its already hitting the hood. is this normal? if i look through the nostrals i can see the front of the box but i cant see the airfilter. is this normal?
Originally Posted by Injuneer
It shouldn't be hitting the hood. Its normal to see the front of the filter box when you look in the grills.
thanks for helping
I have pictures, but the server that they are on is down for some reason.
Do you want a picture of the inside of the hood near the scoop? I can e-mail you that if you do.
I know the box on my car sits a bit high, because of the Griffin radiator. We had to cut a bit off the bottom of the plastic upper radiator support bracket, then screw the bracket directly to the top of the radiator. Even with that, I have the seal strips on the hood, and they just contact the top of the box when the hood closes.
This is kinda unrelated to your posts, but I have an SLP airbox in my SS and it rubs against the bottom of the hood. I wonder if they just made them a tad too high cuz my stock one didn't rub.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
