Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Dash light problem
Old Apr 13, 2009 | 03:11 PM
josh77888's Avatar
Dash light problem
my lights keep going out, i checked the fuse and the fuse was fine.
Is there a way to run another power source to it, cuz its a pain in the *** driving at night cant see how fast im going etc.
Old Apr 14, 2009 | 09:19 AM
bobdec's Avatar
On a '93 Fuse 10 (20A) -to- Headlight switch (exterior lites and headlights, assume they work) brown wire from HL switch goes to Dimmer Switch - drk/grn wire from dimmer goes to fuse 13 (5A) dimmer fuse - gray wire from fuse goes to instrument cluster... You may have a bad dimmer switch or fuse 13 circuit..
Old Apr 14, 2009 | 09:48 AM
josh77888's Avatar
as far as i know the dimmer switch is fine, is there anyway of checking/testing it?
Old Apr 16, 2009 | 09:09 AM
bobdec's Avatar
Put a volt meter on Dimmer Switch drk/grn wire it should vary from +12v to 0V with lites on as you move the dial from full brightness to off..
Old Apr 27, 2009 | 12:59 PM
josh77888's Avatar
im not sure if this applies to anything but when i turn the switch all the way up the dome lights come on so its still operating, could i still have a bad switch?
warmeck
Feb 5, 2015 11:04 AM
Brake_L8
Jan 20, 2015 09:44 AM
97z28k&N
Jan 9, 2015 04:58 AM
fpete1992
Dec 11, 2014 03:51 PM
siguy
Nov 27, 2014 10:07 AM
