Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
my gas needle is stuck on full
Old Jul 2, 2009 | 12:15 AM
shamronwill225's Avatar
does anybody know y my gas needle is stuck on full ...my car is a 96 lt1 trans am ....please help...some one told me that it could b the sending unit ...so i guess if that is it ...once i put in another fuel pump unit,,,the needle will line up with the gas level right...any suggestions ..thanks
Old Jul 2, 2009 | 05:22 AM
The sending unit is defective, or the wiring. No signal = "full". Shoebox has a detailed writeup on checking the system:
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
The sending unit is riveted to the fuel pump support bracket. Many years ago when I replaced the sending unit, it was only available as part of the complete pump support assembly for about $250. Hopefully its available as a separate piece by now. You don't need to replace the fuel pump, but if you do, the sending unit requires no calibration or adjustment.
Magenta_Hearts
Mar 22, 2015 03:36 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
simple
Aug 11, 2002 11:56 AM
